Aller au contenu principal
The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
149 questions Voir tout
HTC One M8 unable to recharge
Hi,
Just as the title says, I have been unable to recharge my HTC M8. I tried using different USB cords without success. Only one of them managed to lit up the recharge light when I insert at certain angle. Otherwise no matter which cords I use, it would not recharge. And I used these USB cords on other phones so I know they are not the issue.
All feedback welcome. I just really don't want to replace it as I have just paid off the phone.
Thank you all.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
I have done the above on my own accord. However, I will try again as I might've not been as cautious as you just dictated. I appreciate your assistance. I will try again. Thank you guys so much. Pleasant weekend:)
par
Ajouter un commentaire
1 Réponse
Solution retenue
Hi,
Visually inspect the phone's USB charge port with a strong light and a magnifying glass.
Verify that all the pins are there (5, especially pins 1 & 5) and that they are all straight and parallel with each other.
Check that there is no lint or dust lodged in the USB port. If so, DO NOT use a metal probe to try and get it out. Try using a vacuum cleaner to suck it out. If this doesn't work try gently (so as to not damage the pins) using a wooden toothpick.
If the USB charge port appears to be OK, insert a USB cord into the port, (you can leave the other end of the cord unplugged) and gently try to move the plug from side to side to check if there is any movement in the USB port. If it feels loose it may have become disconnected from the systemboard. If so, as it is a SMD (surface mounted device) type connector, you will need to have the requisite skills and tools to reconnect it to the systemboard. This is not a job for novices. You can cause more damage than what you started with if you don't know what to do.
If this is the case I recommend that you contact a reputable, professional mobile phone repair service and ask for a quote to repair the phone.
Hopefully this is of some help.
Indice 2
Ajouter une réponse
Snow Prince sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 74
