Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tutoriels de réparation et de dépannage pour la série Presario CQ58. Il s'agit d'ordinateurs portables économiques fabriqués par Compaq, qui a appartenu à HP de 2002 à 2013.
My Laptop can not produce sound when I connect headsets
My laptop can produce sound, disregarding the fact that i updated the sound-drivers when i i connect the headsets, but the pc's speaker does, but it dos not work with headsets.
Répondre à cette question J'ai le même problème
Indice 0
2 commentaires
Hi, When you plug a headset into the earphones socket does it disconnect the sound from the main speakers?
par
yes, that's what happens
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Hi,
Have to ask, you did try another set of headphones didn't you?
It may be that there is a faulty or loose audio output socket in the laptop.
Unfortunately it appears as though the socket is directly mounted onto the motherboard.
Here is a link to the service manual for your laptop. On p.62 it details the necessary pre-requisites and then the procedure to remove the systemboard. You may not have to go this far to initially prove whether the socket is loose or not.
If it is deemed to be faulty then you will need to have the necessary SMD (surface mounted device) soldering skills and tools to remove and replace the socket.
If this seems to daunting for you to do, contact a laptop repair service and ask for a quote to repair the socket.
If you really wish to use headphones and a repair is not an option you could try this alternative solution.
Hopefully this is of some help.
Indice 2
1 commentaire:
thanks for A TIP.. will do that
par
Check your sound settings in "system preferences". Under output select "external headphones?
Indice 0
2 commentaires:
will try that, thanks for a tip
par
i tried that but nothing worked
par
Ajouter une réponse
bernardkathewera sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 438
