Will not drain, spin or operate on any cycle
I already tried power cycling but that was no help. Also tried spin/drain setting but that was no help either.
Lid switch
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Do you get any error codes?
Here's the part: http://www.repairclinic.com/PartDetail/L...
Right below the part is a video on how to install it.
That was the problem on mine +
Yes error code 03
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,202
3 commentaires
Does it power on? I'm guess there's a blown fuse.
par rab777hp
It has power and will turn on
par Rob
Mine too same thing
par mommabear2015
