Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le premier de la nouvelle génération d'appareils Nokia – le premier avec un écran 1080p, le premier avec un processeur Krait quad-core
Phone not working (Nothing can be seen)
Dear Community,
after a time I tried to use my old Lumia 1520 again. At first it didn´t work at all, so I bought a new battery and assembled it. Nevertheless the phone did not work. When I tryed to switch it on, nothing could be seen at the screen. The only reaction was a flashing of the three lower buttons. Though I can acess the storage and reset it via PC, nothing is working. In my opinion the mainboard is damaged. Any help concerning a new mainboard or other troubleshooting suggestions would be grateful.
Count Omega
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire
Thanks for the quick response. In my opinion there could be also the mainboard/screen connecction be damaged as sound ( locking, charging) are working. I´ll try your solution.
Count Omega
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
@count_omega ,Count Omega, Just a thought. Perhaps disassemble the phone and clean all connections(Qtip dampened 90%+ Isopropyl Alcohol) and then reset the connections to be sure of good contact and wires not pinched/broken. While phone is apart use a magnifier to inspect board/components/connectors not(loose,damage,burnt)/solder joints(cracked,etc.) and check that battery is indeed charged. Below is a disassembly link. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Démontage du Nokia Lumia 1520
Indice 1
Does it make sense to remove the chips shielding following the instruction? At the whole phone I couldnt recognize any damages.
Indice 0
Ajouter une réponse
Count Omega sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 13
Total : 335
