Aller au contenu principal
Floor lamps are lights that sit on the floor. They are not table lamps, which are designed to sit on tables. Floor lamps are usually taller than table lamps.
Questions au sujet de 17 Voir tout
trying to determine what replacement to get
I have a floor/torchier lamp with a variable dial switch. I am trying to determine what replacement to get WITHOUT looking like the idiot I am. Any advice?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
@scottdeutsch any chance you can post some images of the current switch and of the lamp? that way we can see what you see Use this guide Ajout d'images à une question existante for that. "variable dial switch" as in a rotary 3-way switch?
Be easy on yourself "WITHOUT looking like the idiot I am" it's only a lamp and you do not want to beat yourself up over it :-))
par
Ajouter un commentaire
1 Réponse
Solution retenue
@scottdeutsch not exactly sure what you reference to a "variable dial switch" is but most Torchiere lamps use a rotary dial switch. They make those for a single filament bulb as well as multifilament bulb. To determine what you have we would have to see the actual switch and the wiring. It should look something like this
Indice 2
Ajouter une réponse
Scott D. Deutsch sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 3
Total : 48
