Aller au contenu principal
The BlackBerry Z10 is a touchscreen-based smartphone developed by BlackBerry, previously known as RIM.
Questions au sujet de 71 Voir tout
it felled in water and brought out fastly within 1 sec
actually i went to pool with my friends one of my friend just dipped it for fraction without knowing and instantly i removed it from his hand and removed the case battery ,sim ,sd card, and all...after some time i inserted i tried to insert battery and tried to start but it loads half and goes off again ...and for one more attempt it gave dead battery symbol and gone off....after some time i tried to charge but no reply from phone ...but when i remove battery and insert the charger it gives red light for 15 sec ...and get off and next day on friend idea i kept it in the rice box air tight enclosed for one day ...,it just as same as gives red light for 15 sec and goes off when only we remove battery and insert charger ....this is the problem ,please help me about the issue
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
2 commentaires
actually today i went to a mobile shop and there he said it would have been short circuited ,think so to change the ic of the mobile ....by checking the mobile using the some equipment thy have at the battery terminals ...can i believe him or not .as the blackberry service is bad at hyderabad centre ,and please say me will the water effect my phone speeaker...?'
par
When you take phone from water gently u should remove all removeable parts and clean with soft clothes and then you should use blow drier to remove water from speaker, charge porter.then u should kept it in the rice box air tight enclosed for two or three days.phone will be turn by this method.
par
Ajouter un commentaire
1 Réponse
Solution retenue
First of all get the phone out of the rice it does nothing but waste valuable time when you could be fixing your phone
Clean every connection with a soft toothbrush. As well clean the logic board; use a 99% isopropyl alcohol for all cleaning. Now is the time to start drying out the phone. Set the screen in a desiccant or silica gel leave it in for several days moving it from time to time to get the max effect from the desiccant. Use a blow dryer on a low heat setting to dry the rest of the phone. Only use a hair dryer once you have cleaned the phone completely with the alcohol. Do not attempt to dry the phone if it’s still wet with water with the blow dryer as this only spreads the water. Replace the battery with a new one considers the old ones done. Clean again with isopropyl alcohol let dry and when you think everything is clean and dry reassemble the phone (make sure to clean the contacts on the screen after removing from the desiccant). Once you've reassembled the phone it’s time to power it on. Hold your breath and hope for the best
BlackBerry Z10 Teardown
Indice 5
Ajouter une réponse
vivek.kakkireni19 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 58
