Aller au contenu principal
La version 2016 de la série d'ordinateurs portables Apple destinés aux professionnels. Dispose d'un écran Retina de 15 pouces, d'une résolution de 2880 sur 1800 pouces, processeur quad-core Intel Core i7, 256 Go / 512 Go /1 To / 2 To en options de stockage, RAM de 16 Go et un clavier équipé deTouch Bar. Sorti en novembre 2016. Numéro de modèle A1707.
260 questions Voir tout
Water damaged touch bar playing up
Okay so i got my lovely macbook damaged by the rain the other week, and took it to a repair shop who said that it wouldn't even turn on and is 'uneconomical' to repair. However when i got back i put it near a heater for a few hours and now everything on it works fine (apart from a little bit of screen damage but thats livable), the only thing that doesn't work is the touch bar, i cannot use it and more importantly, it randomly selects buttons by itself every 20 seconds or so. Is there any way to disable or relace the touchbar? what would happen if i just cut the cord?
thanks for your time
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
4 Réponses
hey James.
As it turns our, the touchbar is essentially impossible to replace by itself as it's glued to the top case.
The only way to truly repair the computer is to have apple send it out for repair which I think is like 1600 bucks... :(
Indice 0
it could be a connector? did you ever get this fixed and find out what happened? having the same issues.
Indice 0
2 commentaires:
Hello
The laptop ended up dying from the water damage so never got the chance to cut the cable and see what would happen
good luck!!
par
@james.harwood5 gotcha thx
par
nothing should happen if you cut the cord. but if you invest in a top cover witch holds your keyboard and touchpad it has a lot of scews and needs to be put perfect and mind the fact it has to be identical to the apple mac book for this to work. just requires alot of attention and detailed take apart and reassembled. if you havent took one apart dont advise you do it. might just be worth adding a usb mouse and keyboard for the cheapest method in a fix. is all i could say. hope this works for you.
Indice 0
Hey did you get the solution to this? My touch bar on my ipad has some water too, and it randomly starts playing around with the controls.
Let me know what you did and if that helped!
Indice 0
1 commentaire:
Hello. No it stopped turning on before i had the chance to cut the cord. It is upto you what you do, but looking back i wish i just sold it and cut my losses.
Good luck!
par
Ajouter une réponse
james.harwood5 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 1,181
