Aller au contenu principal
Console de jeux de 3ème génération de Microsoft, lancée le 22 novembre 2013.
727 questions Voir tout
No orange light when plugged into console
My Xbox One wont turn on and the orange light turns off when I plug the power bar in to the Console
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
1 commentaire
Ya i have tried another PowerBrick and all it was doing was flickering orange
par
Ajouter un commentaire
2 Réponses
Solution retenue
Presently working on a psu for xbox. Orange light goes off as soon as box turned on. This supply has a 5v standby supply and a 12v run supply. As soon as the run supply was activated, the ps shuts down. Thats because i found shorted transistors in the primary side of the run supply. This needs a competent technician to repair this. Looks like a surface mount capacitor has had some arcing across its surface. Mosfet defintely shorted.
Indice 0
1 commentaire:
Can you give a bit more detail which transistors you are talking about that were shorted? Is this inside the PSU or the actual Xbox Motherboard?
par
Réponse la plus utile
This guide might help. Clean the brick with caned air when you put back together. Démontage du bloc d'alimentation de la Xbox One (Édition Day One)
And this guide might help to. Xbox One Motherboard Replacement
It sounds like a power issue the board might be shorted out so use a multi meter and check all solder marks and traces. Make sure they all get the right amount of power.
If you have any questions or concerns please comment below or email me at walker44805@gmail.com !
Image Xbox One Motherboard
Tutoriel
Difficulté :
Modérée
30 minutes - 1 hour
Image Xbox One
Tutoriel
Difficulté :
Modérée
30 - 45 minutes
Indice 1
Ajouter une réponse
Vimpulse sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 6
30 derniers jours : 14
Total : 8,249
