Aller au contenu principal
The second generation of the Ford Ranger, featuring a mild restyling and new engine sizing.
Questions au sujet de 36 Voir tout
How can I stop oil from leaking from the spark plug hole?
My 1993 Ford Ranger uses 2 quarts of oil a week. I changed the spark plugs and one had oil all over and inside the hole where the plug screws in.
Répondre à cette question J'ai le même problème
Indice 0
Commentaires:
my spark plug had oil but are too much ,is that normal found plug like that?
par
Ajouter un commentaire
2 solutions
Réponse la plus utile
I bought a couple of spark plug oil seal from 4WheelOnline and a couple of truck accessories. I did the repair by myself. Its a 1-hour job.
Cette réponse a-t-elle été utile ?
Indice 2
Change out the tappet cover gasket, unless they are in the side of your head. If that is the case then it is most likely that your plugs are fouling with oil due to either worn rings or leaky valve stem seals.
Indice 1
Ajouter une réponse
tinalougarrison sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,195
