Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Une cafetière domestique fabriquée par Keurig, sortie en 2011. La réparation de cet appareil est similaire à celle de tous les autres modèles Keurig.
I think I need to replace the waterpump on my keurig65
The Keurig leaks water during the pump operation, I have replace water resivoir thinking it was o rings. Water leak continued. I took keurig apart and is seems to have a back leak from the water pump, when water is pumped in heat resivoir some water reverses direction and back leaks out of bottom of keurig, at the point of water filter. I am unsure of which parts I should change. Can you give me some suggestions? I don't know if it is worth salvaging coffee maker......but I hate just chucking things in the trash.
Répondre à cette question J'ai le même problème
Indice 5
Ajouter un commentaire
2 Réponses
Réponse la plus utile
It looks like a lot of the models use the same water pump.
Ebay sells these for around $15-$20
http://www.ebay.com/bhp/keurig-water-pum...
iFixit has a guide for the k75 that may be similar to your model on replacing the water pump.
Changement pompe à eau Keurig K75
Indice 2
1 commentaire:
Thank you I will try this appreciate the help, part is on order in the mean time I will take apart and see if I can clean it.
par
I replace all my lone, well almost with home depot/lowes 5/16 ID hose, and 4” White zip ties TIGHT AS !&&*, and no more leaks, im not taking the case off again but ill pop the top off real quick (2 screws, takes 5 seconds)
Indice 0
1 commentaire:
And yes. I melted my 1 way valve boiling it clean, ordered a new one off ebay for 6.75 but it runs fine without it currently, as long as you get a 4psi valve that fits under hood it doesn't have to be jeurig either just that it accepts 5/16 ID and is 4psi
par
Ajouter une réponse
Martha Havranek sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 25
Total : 2,056
