How to install bluetooth antenna
Since the original iMac G5 17" 1.6/1.8 GHz model did not include Bluetooth, unless it was Build-to-Order, the Bluetooth antenna is not installed. You have a guide for replacing the Bluetooth board, but you don't have a guide for installing or replacing the Bluetooth Antenna. Bluetooth boards and antennas are available on eBay, but no guide is available for installing the Bluetooth antenna. Can you do one?
Hi Peter, I'm in the same situation as you, I've bought the Antenna but can't find instructions on how to install it! Have you found any yet?
Tony
par Tony Chadwick
No. I sold the iMac G5 without adding the Bluetooth board. In the previous iMac G4 17", Apple included the Bluetooth antenna pre-installed, even if Bluetooth was not ordered as BTO. So all you had to do was add the BT board and plug in the antenna. I was disappointed to find out that Apple did not include the BT antenna in the iMac G5. I did not feel like disassembling the entire iMac to install the BT antenna, so I just sold it without BT.
par Peter Hillman
