Aller au contenu principal
Toyota released the 2002-2006 Camry XV30 series as a larger sedan in September 2001 for the 2002 model year.
20 questions Voir tout
The clutch will not engage at all I'm wondering is it a slave cylinder
2002 Toyota Camry CSI
The clutch when engaged or disengage with the purpl
The clutch does not drive the car forward and is not over reving & no clutch plate smell is coming from the gear box and I was wondering is it the slave cylinder buggered, or is the clutch that is needing replacing.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
@timothymoad ,Timothy, Look to see if the pin from the clutch fork to the slave cylinder is sitting somewhat loose/has a little movement(not extended) when clutch peddle is not pushed, if some what free/movement then the slave is not stuck on and would suggest the problem lays further in the system. Probable clutch disc/pressure plate either worn or hanging up on bearing/fork. If things feel some what normal and the vehicle does not want to move,may be a broken CV joint on the axle. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Indice 3
Ajouter une réponse
Timothy Moad sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 1,749
