Fuel system flow problem. Engine will not start and run
My golf cart will not start this spring. It appears that it is starving for fuel. I have replaced the fuel filters, fuel pump, and checked the fuel lines. It still will not run. Do I need to prefill the gas lines and filters? Could the engine be shot and not creating enough compression to run the fuel pump?
6 commentaires
My 2006 Club Car fan out of fuel Sunday. I filled the tank, and now it won't fire. The fuel filter is empty. what should I do?
par reisterhold
I have the same problem, filter fills with air then motor runs out of gas. I use a hypodermic needle to fill filter and it runs for a day. Replaced filter and gas line to tank and dip tube and that did not fix it, sure would like to get it fixed.
Chuck
par cgwpm
New fuel line, new fuel pump, new carburetor, starving for gas. Fill the line from the pump to carburetor and runs great until it runs out. Vacuum lines working good. Any thoughts?
par Dale
I just had this problem when I went to take my Yamaha golf cart out of winter storage. After consulting owner manual and performing basic checks I happen to notice fuel filter was empty. Gas tank was also low. Added more gas to tank and tried to choke and start with no success. I eventually had to disconnect the fuel line from filter Disconnected the first gas line out of tank to filter and started siphoning with my mouth and then reattached line to filter. Had to choke hard and constant few secs before the filter filled and the line to the carburetor then it fired right up. Thankful that’s all it was. Also has anyone replaced tires or upgraded to a knobby off road style? I am on a farm and use it to get around quick and tow a small wagon. Happy riding
par psr2255@gmail.com
I had all kinds of problems with my 1986 club car stalling and not getting gas. I replaced the fuel lines, filters, fuel pump and even the carburetor. Nothing helped, then I noticed the vacum or pulse line from the engine to the fuel pump was missing a clamp that attached to the fuel pump, I put a clamp on snugged it up and my problem was solved.
par Cal Moore
Afficher 1 commentaire en plus
