Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sony M-430 Microcassette-Corder can record and play back audio. The one-touch recording and two-speed record/playback and automatic shut-off makes this ideal for on the go recording. Model number M430.
The spinners aren't working
I just found an old Microcassette recorder and it worked at first, but after awhile they stopped working and now when I rewind it makes a buzzing noise. Also the little switch on the side has become loose and I can't seem to get it to stay in one spot.
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
1 Réponse
Solution retenue
@flamma sounds lik you are having issues with the drive belt. Use these guides to check it out. you will have to unsolder the main board to get to the mechanism deck that includes the motor and the drive belt. Once you have the recorder open, post some images of what you see with your question. Use this guide for that. It will allow us to see what you see.
Indice 3
Ajouter une réponse
Jake door sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 18
Total : 1,821
