Aller au contenu principal
Sorti le 19 septembre 2014, cet iPhone avec un écran de 4,7 pouces est une version plus petite de l'iPhone 6 Plus. Identifiables par les numéros de modèle A1549, A1586, et A1589.
Questions au sujet de 4961 Voir tout
iPhone 6 error 56
I have an iphone 6 that was updated thru settings to latest iOS and failed and needed to be restore with iTunes. I did so like 5 times now and it keeps failing with error 56. I've tried new cables, new dock connector, latest iTunes, tied both windows and Mac OS but it keeps giving the error. what causes this and how can I fix it? Thanks
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Commentaires:
Hi I have the same problem on iPhone se and i fixit. What i was try to do was remove the battery connector to drain the power from the phone but as i use screwdriver to remove the conector there was sparcle so I thing the phone reset as when i try to turn the phone on it show low battery logo and after i restore the phone and it work.
par
Ajouter un commentaire
4 Réponses
Solution retenue
Asked and answered:
What is (unknown error 56) iPhone 6
Indice 4
100% solution
NFC IC REBALL & JOB DONE
100% TESTED
Indice 1
Commentaires:
hello brother
i have done for your idea
very thanks
but my iphone 6 done for error 56 but wifi not work it's Gaye
par
Yeah from days of research and a @%^$$@$ iPhone that is still stuck, I have concluded that it is either the NFC chip (which was working perfectly fine, I have no idea why it died), or my touch id button (tried original and spare ones, original is cracked and touch id may no longer work, but chip on it is in working condition, or my cables/$@$*!& wiring. Someone please help me before I hang myself. Why are androids so easy to fix and iPhones stubborn @%^$$@$# who can't take the slightest beating from command prompt or terminal? Its always the iTunes $@$* that gets me every time. Anyways I am buying a new iPhone tomorrow with hopes that I can have a working phone, but chraiglsist seller isn't responding and I am getting nervous and sad. &&^&^$^ !&&* I am killing myself.
Indice 1
Commentaires:
I relate in many ways
par
sometimes error 56 is caused by the power supply of camera on iphone 6.
exchange the both camera(which i dont think it would works) and check the cricket might fix ur problem.
Indice 0
Ajouter une réponse
CAB sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 3,603
