Aller au contenu principal
Nous pourrions faire tellement de choses si nous savions comment procéder. Cette page aspire à cataloguer la plupart des compétences nécessaires pour exécuter certaines sortes de réparation.
Questions au sujet de 417 Voir tout
What is the best way to dry used desiccant Silica-Gel?
I like to keep gadgets together with the accessories - an ideal way to store is a ziploc bag. Condensation is a worry with all electronics - therefore I want to use the small bags of desiccant that come with all sort of things.
What is the best way to dry these / restore them before use?
Répondu ! Afficher la réponse J'ai le même problème
Indice 5
Ajouter un commentaire
6 Réponses
Solution retenue
Let the packets bake on a cookie sheet in your oven at 150 degrees for 12-18 minutes or so. Allow them to cool and they should be ready to go. Alternatively, you can find new ones on the internet for a relatively low cost.
Indice 10
Commentaires:
I accepted this answer as it attracted a score of 3 - meaning to me others think too this is the may to go. Thank You
par
Put the containers you intend to store the gel in the oven with the gel (air tight ones). Unless your camera equipment is in airtight containers the gel won't be effective for more than a short time, so you would have to change them regularly, as they will draw moisture from the wider area and become useless quickly
par
I know it's been a while but did you mean 150 degrees Fahrenheit or Celsius?
par
dry in a food dehydrator 120 f or 50 c for 2 or more hours i do this with color changing this works good
Indice 3
Commentaires:
Awesome... This info was really helpful. You should get more up-votes for this, definitely!
par
Just leave them a day in the sun, it will do.
Indice 1
Commentaires:
Actually, that depends on where you live. If you're in a very low humidity area, might work. In Florida? Forget it!
par
IF it is a color changing Silica Gel, it can be reheated to 248 degrees Farenheit or 120 degrees Celsius to reset the colour change. As soon as the color has reverted, it can be re-used.
Indice 1
leave it in the sun ...
some say put in oven or microwave, but limited tries...
perhaps for long term, can consider a dry box.
Indice 1
silica gels adsorb moisture, so simply drying them under sun is simple technique...
Indice -1
Commentaires:
If you liked miguel answer just vote it up, don't repeat it.
par
well, if u see it repeated, then you got better lots of time to see who repeats others, keep going.
par
par
Ajouter une réponse
Spikey2 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 12
7 derniers jours : 102
30 derniers jours : 446
Total : 35,102
