Aller au contenu principal
Sorti le 19 septembre 2014, cet iPhone avec un écran de 4,7 pouces est une version plus petite de l'iPhone 6 Plus. Identifiables par les numéros de modèle A1549, A1586, et A1589.
Questions au sujet de 5202 Voir tout
iPhone 6 won't turn on after sensor flex replacement
HI ,
recently i changed my sensor flex cable because my old sensor was not working .
unfortunately i forget to remove the power cable before disassembling .
now my iPhone won't turn on .. not taking charging and even not detected by iTunes .
anyone can help me out .
thanks in advance .
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Commentaires:
Does it works ? :) Enjoy your phone :) im happy that it helps you :)
par
Did you plugged it in with your cable ?
par
hi .. still same .. won't on :(
par
Try charging it if it will work ?
par
yes it was plugged in with my own cable ... but not with charger with my laptop only .
par
Voir 2 commentaires en plus
Ajouter un commentaire
2 solutions
Solution retenue
Just unplug the battery return it back on your phone is okay for sure :)
Cette réponse a-t-elle été utile ?
Indice 0
Commentaires:
Hi ,
thanks for the reply .
did the same but no luck .. any other idea ?
par
Maybe its a battery problem already bro .You damaged your battery .
par
hi ,
battery is new .. i mean phone is only two months old .
sensor replacement can damage battery ??
par
Réponse la plus utile
What do you mean by sensor replacement? Is that the front camera ribbon cable flex assembly?
Did you try booting up the phone with front camera flex and home button extension cable unplugged from logic board?
Have you made sure not to put the longer screws into the 3 screw holes on the board to avoid long screw damage?
Indice 2
Commentaires:
Hi Ben
Yes it was sensor flex cable with front camera.
I tried booting up after assembling everything on logic board.
& I am 200% sure it was not longer screw damage because i tried booting without that plate and screw.
Tried with new battery and new sceen but no luck ...
Do you have any other idea .. thanks
par
Ajouter une réponse
vinod sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 107
