Aller au contenu principal
Pour réparer ensemble - Je crée un compte
An audio storage device that uses magnetic tape to record and play back audio input.
motor wont run when switched to forward or reverse
I have a teac tape recorder a-2050, when power is on , the vu meters lite up and if I activate one of the two micro-switches the motor runs,but if the long bar switch to allow the tape to play, the motor will not run, in the back I can see the relay pull in and thats the only indication that some thing is alive. I have worked on tv and radios with schematics but have nothing for this.
Duane
Répondre à cette question J'ai le même problème
Indice -1
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Use a multimeter to test the switch. If you plan on keeping the machine consider buying the repair manual for it. I found this one on eBay: http://cgi.ebay.com/TEAC-A-2010-A-2050-A...
Indice 2
These run on 4 idler wheels under the front panel that drives the capstan motor. They are probably gummy and deteriorated.
Indice 1
Ajouter une réponse
kb9zqu2000 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 42
Total : 870
