Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The iRobot Roomba 655 Pet Series vacuum manufactured in 2012. Costco exclusive.
Side brush isn't working.
The side brush isn't working anymore. I've replaced the entire side brush unit and it will do a .25 revolution once it starts cleaning then the side brush will not work. I've striped it down and cleaned everything that could be cleaned. I am At a loss here no idea what's up and I-robot told me to buy a new one when I called the help line.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
Did you solved the problem? I have the exact same thing, replaced the module, still not spinning :-(
par
Ajouter un commentaire
1 Réponse
Solution retenue
@bobo006, Ben, If you have already replaced the side brush motor and still not working, check the wires and connector for being, loose/damaged/corroded/check the connector with DVOM to ensure power is getting to the motor and make necessary repairs if defect found. If motor has not been replaced perhaps consider replacing motor. 1st link below is a guide to replacing side brush motor and 2nd link will get you inside to inspect the mother board for loose/damaged/burnt components. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
iRobot Roomba 655 Pet Series Side Brush Motor Replacement
iRobot Roomba 655 Pet Series Motherboard Replacement
Image iRobot Roomba 655 Pet Series Motherboard
Tutoriel
Difficulté :
Difficile
2 - 3 hours
Image iRobot Roomba 655 Pet Series Side Brush Motor
Tutoriel
Difficulté :
Modérée
10 - 15 minutes
Indice 2
2 commentaires:
My roomba side brush remains on. This happened after my roomba got wet. What can I do?
par
Be sure the central screw on the brush is not too tight. Even though you can turn it with your fingers Roomba will detect a TANGLE if its too tight and shut it down.
par
Ajouter une réponse
Ben sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 14
Total : 4,352
