Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Annoncé en mars 2015, puis commercialisé le 10 avril 2015, le Galaxy S6 est le prochain flagship de la série Galaxy. La version avec un écran incurvé est connue en tant que Galaxy S6 Edge.
Questions au sujet de 463 Voir tout
It will turn on but only charge to 50%
My samsung galaxy S6 got rained on, and since then it will turn on and screen looks normal and functions normally, but it will only charge to 50%, but when I unplug it then it dies. Do I need to replace the charging daughter board? If I do, then will the home button finger ID still work?
Répondu ! View the answer J'ai le même problème
Commentaires:
Both front and back are cracked, between replacing the battery and both front and back glass. Is it cheaper to replace phone?
par
Unless you know how to do a glass only repair, it is usually not worth fixing. If the LCD is black, I would just get a replacement then.
par
Ajouter un commentaire
2 solutions
Solution retenue
Sounds like your battery is failing to due liquid. Any time you get liquid on a battery, you want to go with a new one. I would first try a new battery before replacing the daughterboard. If battery fails, then try the board. That should solve any issues you are having with this device.
Remplacement de la batterie du Samsung Galaxy S6
Remplacement de la carte fille du Samsung Galaxy S6
Image Samsung Galaxy S6 Batterie
Tutoriel
Difficulté :
Difficile
40 minutes - 1 hour
Image Samsung Galaxy S6 Carte fille
Tutoriel
Difficulté :
Difficile
45 minutes - 2 hours
Cette réponse a-t-elle été utile ?
Both front and back glass is cracked, and bad battery, with all of these repairs, would it be cheaper to replace the phone?
Ajouter une réponse
Amy ford sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 55
