Aller au contenu principal
La version 2016 de la série d'ordinateurs portables Apple destinés aux professionnels. Dispose d'un écran Retina de 15 pouces, d'une résolution de 2880 sur 1800 pouces, processeur quad-core Intel Core i7, 256 Go / 512 Go /1 To / 2 To en options de stockage, RAM de 16 Go et un clavier équipé deTouch Bar. Sorti en novembre 2016. Numéro de modèle A1707.
266 questions Voir tout
Driver for opening MacBook Pro touch bar
Please can you tell me which drivers I need to open up MacBook Pro 15" Touch Bar Late 2016?
Are they available at Ifixit?
Best Regards,
Eric
Répondre à cette question J'ai le même problème
Indice 0
3 commentaires
Are you sure you need to open it?
Before you open your system this series does not have removable RAM or storage (SSD).
You may want to tell us why you need to open such a new system.
par
Yes,.. Water damage....
par
Sorry to hear that ;-{
If you can't get it working after you dry it out you still might be able to gain access to the SSD. Apple has a header on the logic board which we think is a direct port to the SSD. You may need to talk with Apple or authorized service center to see if they can connect your system to another to down load what it had on the SSD.
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Looks like the P5, P3 & T5 driver are the main ones listed in the teardown:
Vue éclatée du MacBook Pro 15" Touch Bar
Indice 3
From what I understand the P5 Pentalobe Screwdriver Retina MacBook Pro and Air is still needed for this newer model.
I do recommend you get one of the full kits as there are other tools you'll need. I would recommend this one: Pro Tech Tool kit as it has the non metal wedges and spudger tools which you'll need. It has the full selection of bits needed.
Image P5 Pentalobe Screwdriver Retina MacBook Pro and Air
Produit
$5.99
Image Pro Tech Toolkit
Produit
Pro Tech Toolkit
$74.95
Indice 0
Ajouter une réponse
nedon sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 2,322
