Aller au contenu principal
Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
342 questions Voir tout
Replacement HD won't boot
I just replaced a Samsung 500g hd with a WD Caviar 2tb hd in my new iMac 21.5 (iMac 11,2) and when it boots, I get a flashing question mark.
Do I need a Samsung hd instead of an WD?
I thought Wds were compatible.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
You need to boot from your system installation disk. Insert disk and hold down the "C" key while starting up. Go to the second page pull down menu to Utilities, Disk Utility and format the drive. Give it one partition. Now go ahead and install a system.
Remplacement du SSD dans l'iMac Intel 21,5" EMC 2389 EMC 2428
Indice 3
2 commentaires:
The HD is not recognized at all and I believe it has to do with me using a different brand. I am going to get the right temp. sensor cable and see if that helps.
par
The OWC temperature sensor will not help you to see the drive, it will just stop the run away fan issue if you have changed hard drive brands.
par
Ajouter une réponse
erin sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 773
