My ps2 is no longer showing pictures
The play station is no longer showing picture just like that, I opened it nd clean everywhere but is still not showing
likely one of two things.
1) A damage component cable port. (pins inside or behind the port are likey damaged, and it needs to be replaced.) This repair needs to be done by ones self, as the labor is more expensive than buying the system.
2) your GPU oveheated, and the board needs to be replaced. replacing the board is similar in cost to buying a new device.
these items are cheap. 40-80$ depending on where and when. so i would just look at replacing at your local game store.
How do I repair it
disassemble the PS2, and remove the board. Apply heated air to approximately 300 degreesC to the location of the port for your imaging cables, and remove it when the solder melts. at this point, you will need to purchase a new port, and install it by doing the same thing.
This is a High Difficulty repair, and if you dont have a lot of soldering skills, i advise against it. sourcing the parts can be difficult, as they are not sold by certified providers, since it doesnt make sense to sell a repair of this quality.
(im assuming you have tried replacing your component cables prior to this, as well as tried it in a second video port on another TV, and it did not work.) <-- DO THIS FIRST TO VERIFY IT IS NOT A FAILING CABLE or TV
Dernières 24 heures : 4
7 derniers jours : 5
30 derniers jours : 18
Total : 3,134
