Aller au contenu principal
The tenth generation Corolla (E140/E150) was released in Japan in October 2006. A narrow variant was available in Japan while wider versions were sold internationally.
when installing new battery the horn sounds. how to stop this?
As soon as the system gets electricity, the horn sounds in an off and on pattern. How can I stop this and install the battery. Alternatively, where is the horn wire to disconnect it?
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
2 commentaires
I am putting new battery in car . When i connect horn goes off won't
par
Check if you are connecting the correct battery terminals.
par
Ajouter un commentaire
2 Réponses
Solution retenue
Answering my own question: Hook up the battery, then use the remote (car alarm button) to turn off the horn.
Indice 2
1 commentaire:
What if you don't have a key fob
par
If the beeping persists because your key fob does not work or has a low battery itself, endure the beep until you can start the engine of your vehicle.
Indice 2
2 commentaires:
Even when I get the car running thorn keeps beeping! Now what?
par
Start the car, put in reverse, drive and shut off the engine.
par
Ajouter une réponse
TWB sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 14
Total : 27,087
