Next for me was the power button not working. I was about to buy a universal remote then thought, I'm going to spend $75+ on an on/off and volume up/down button?
So I gave opening the remote one more try seeing as I now had nothing to lose. Found a decent smallish flat head screwdriver and started to pry - con gusto. Pop came the first one and prying around the remote I was able to open it all up.
In my case it wasn't so much dirt as some sticky film on the buttons. In the holes of the rigid plastic was some debris which I scraped out. As for the film, no doubt a late night spilled scotch, I just went at it with paper towel and the flat head acting as a mini scraper.
When it all looked about as good as it could get I put it back, reinserted the batteries and the thing came to life. Tested it out on the plasma and holy cow I now had both power on and volume up/down.
For some reason I feel like blowing $75!
Thanks André. Had it not been for you I would never have attempted this.
bob
waterloo, ontario, canada
A voté
Annuler
Indice
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
3 commentaires
This seems to be a common problem and I don't know how to fix it either. Good luck to both of us because a new remote is $75!
par Lynn B
It's the black press button on the inside that is worn out. I have tried a number of ways to clean it but it only works intermittently. I used other buttons on the silicone base and it worked fine, so isolated to this up button. Looking for a new remote.
Geno
par ginobeno
You can buy a special repair kit for remotes at electronics stores, the kit will have some patches for those black connectors and some glue to attach them - works fine.
par gertschultz
