Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
La version d'avril 2014 du MacBook Air 13" d'Apple offre des processeurs dual-core i5 et i7 mise à jour ainsi qu'une batterie aux performances améliorées.
Questions au sujet de 249 Voir tout
built-in keyboard and trackpad option not showing in preferences
Two weeks ago I turned on my MacBook Air the built-in keyboard and trackpad wasn't working! I have an USB keyboard and a magic mouse connected now to the system so I could still use it.
I went to the system preferences but for some strange reason the option ignore built-in keyboard and trackpad when bla bla bla .... is not available.
I've already reset SMC and NVRAM, battery is ok...
By the way when the system boots up the keyboard works but then it immediately stops working.
I've already ran the option+d combination and the test shows no errors.
This is an image of my system preferences / accesibility / mouse & trackpad
MacBookAir6,2 (A1466)
Répondu ! View the answer J'ai le même problème
Indice 1
Commentaires:
Can you give us your exact model as there are quite a few different versions of the 13" MacBook Pro.
par
Helio, thanks for your reply...the model is MacBookAir6,2 (A1466)
par
Ajouter un commentaire
ÉTUDIEZ N'IMPORTE OÙ
Fix Kits pour batteries de Mac
Voir les Fix Kits
Voir les Fix Kits
1 solution
Solution retenue
It sounds like you may have damaged the trackpad and/or the ribbon cable leading from it to your logic board. In this series both the keyboard & trackpad signals travel thru this one cable. What can happen is a liquid spill can get to the back of the trackpad corroding the contacts. Here's the IFIXIT guide you'll need to follow: MacBook Air 13" Early 2014 Trackpad Replacement and here's the two parts MacBook Air 13" (Mid 2013-2017) Trackpad & MacBook Air 13" (Mid 2013-2017) Trackpad Cable
Image MacBook Air 13" (Mid 2013-2017) Trackpad Cable
Produit
$14,99
Produit
$89,99
Cette réponse a-t-elle été utile ?
Indice 2
Ajouter une réponse
raul sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 18
Total : 906
