MBA 11 - Keyboard and Trackpad not working
GUYS,
REALLY WEIRD PROBLEM
I have a Macbook Air 11" A1465
My keyboard and trackpad aren´t working. So I made a clean install of sierra (deleting everything from the SSD) before install the brand new SYSTEM.
It worked 100% fine all the time. However when I finished installing the system and after updating it, "INK" appears on the system preference and is what is HAVING CONFLICT
I tried deleting some of the com.apple.ink files on /Library/Preferences and it still appears on the system preference and keyboard and trackpad doesnt function.
THEN
I tried deleting the Ink.prefPane on /System/Library/PreferecePanes and it gives me a message: "cannot be deleted required by macOS"
THEN
I tried using
sudo chmod - R 0777
sudo -R
chflags nouch
I tried
NONE OF THEM WORKED.
What ELSE can I do to remove completely and FORBID INK to install by itself on my MBA 11 using macOS Sierra?
@angelorecaman why do you think your problem is strictly software related?
par Oros
I would check the trackpad and keyboard in the boot menu. I think you hold command or alt while turning the MacBook on. There you can use trackpad to move mouse cursor around and keyboard for wifi network.
par Ben
Ben.
I already did and it is working 100%. It seems to stop working after loading some of the system files on the system loading screen suddenly it stop working. I use CAPS LOCK light to CHECK it.
par Angelo Recaman
