Aller au contenu principal
L'Apple iPhone 5s fut annoncé le 10 septembre 2013. La réparation de ce modèle est très similaire aux modèles précédents et requiert des tournevis ainsi que des outils pour faire levier. Disponible en version GSM ou CDMA, 16/32/64 Go de stockage et en argent, doré ou gris sidéral.
Questions au sujet de 3512 Voir tout
What is causing screen issue after iPhone 5s battery replacement?
Hi,
I just replaced my iphone 5s battery and everything is working except for an issue with my screen when I press with moderate pressure. (I have linked a video to show what it looks like). What is it that causes this?
https://vimeo.com/229741314
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
Those are pressure marks. That means something isn't sitting right underneath the screen and it applies pressure against the LCD when you press.
Go back through the battery replacement guide and check to make sure everything is in place. If you removed anything else to get at the battery (i.e. the Dock), then check that as well.
Indice 2
5 commentaires:
Ok thanks!- I will redo it now and see how it goes
par
If you found this answer helpful, please select "Was this answer helpful? - YES" and/or if this answer solved your problem, please “Choose as Solution”. This allows people in the future to understand which answers helped solve the problem and adds value to the site. - Thanks
par
yes According to my experience Those are pressure marks. the battery isn't sitting right.
par
Nice! thanks so much. It was how I installed the new adhesive tape, the tab was stuck to the front side of the battery and must have made contact with the LCD back plate.
par
My pleasure!
par
Ajouter une réponse
Sohan sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 149
