Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Le plus large parmi les MacBook Air Apple, disposant d'un microphone double et d'une connexion Wi-Fi 802.11ac.
Questions au sujet de 442 Voir tout
How to fix the blinking question mark folder?
I have this blinking question mark folder on my screen.
I looked for the solutions and I found that it's not the hard drive problem, but the cable that connects the hard drive...
So I tried to order a new cable and replace it, but I just found that MacBook Air 2013 (A1446) does not have the connecting cable... ;(
It has a solid(?) or fixed SSD adapter instead.
So is there any way that I can replace the adapter (?) of SSD? (not SSD board itself)
Or... Is there any other solution?
Répondu ! View the answer J'ai le même problème
Indice 0
Ajouter un commentaire
Le kit d'outils Essentiel
Les outils les plus utiles dans notre kit le plus compact.
J'achète
J'achète
2 solutions
Solution retenue
A little bit of knowledge can be dangerous. The likelihood of this being a bad SSD is low and there is no cable the SSD connection is integrated into the logic board. Most likely is that you have a corrupted system folder. Reboot the machine holding down the option key and select the repair partition. Run Disk Utilities on the drive and see if you can repair it. That failing you can then try a reinstall of the system.
Cette réponse a-t-elle été utile ?
Indice 2
Réponse la plus utile
The blinking question mark usually happens with faulty drive in this series.
Inspect your SSD connector to logic board for corrosion or damage. Most likely your SSD drive is gone.
You'll need to test it with an Apple SSD to USB adapter and connect it another Mac, or buy new SSD.
MacBook Air 2013 SSD's are PCIe based. Proprietary to Apple as explained here:
EveryMac - MacBook Air Q&A
Remplacement du disque dur SSD du MacBook Air 13" mi-2013
Indice 3
Commentaires:
OWC offers the required SSD and the carrier to hold it: SSD Flash Storage Options For MacBook Air 13" 2013 - 2017
par
Thanks a lot for the answer
par
Ajouter une réponse
정찬경 sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 16
Total : 7,390
