See if this helps:
On the front of the receiver (the part that you wear) is a large black volume dial. This large dial acts like a "cog" and turns a smaller internal volume dial. In a scenario where the volume control of the Set 830 or Set 840 does not appear to be functioning correctly it may be a situation where the dials are out of alignment.
The solution is to realign the dials. To do this follow these steps:
Step 1: Remove the large black dial. (It pops straight off).
Step 2: Turn the volume all the way down by adjusting the small internal dial. (The small dial is grey colored and about the size of a dime).
Step 3: Re-align the large black dial with the "0" just to the RIGHT of the "12 o'clock" position and click it back into place.
Step 4: Test the volume.
Step 5: You're all set.
A voté
Annuler
Indice
3 commentaires
Hi Seth
I just am experiencing the same problem with my 4.5s if you have found out any was to solve them or any repair place that does please let me know my email is lorcanscience@gmail.com thank you and best of luck finding a solution .
par Lorcan O'Malley
Have this problem too, did you find a solution?
If so please send me an email:
naniux3000@outlook.com
par naniux nano
I just dropped my headphones the vol down is working but the vol up is NOT if found a solution please contact me tarunraj091@hotmail.com
par tarunraj091
