Disassemble and replace the two Stabilizer boards and ribbon cables.
The stabilizer may get damaged when the drone loses connectivity and crashes. The plastic housing (which contains the electronics) that plugs into the drone is bolted on with 5 bolts. That housing can break apart ripping the stabilizer in two. I need to source and replace the housing and the electronics to salvage the rest of the stabilizer. Any chance you have that information and want to make a video of the process?
Stabilizer codes that I can see:
-outside housing-MISP-REM-WD7-KWCY1
-large board- 656-10811 Rev A
--this board has two snap-in ribbon cables and one slide in 3 cable connector (the connector ripped of the board)
-small board- couldn't see it
-three ribbon cables
--656-11925-000 REV A
--656-19296-000 REV A (MOT -170804261)
-- this one ripped in two. Can't see code until taken apart.
- stabilizer has a code inside it: E5272800335148 (which is printed on the part that is not part of the broken plastic housing.)
- I can send photos if necessary. Thank you.
I have the same problem. That housing can break apart ripping the stabilizer in two pieces. And also the ribbon cables teared. I'm looking for a shop can i buy these items.
par Máté Tallósi
