Why won't my unitbturn back on?
The power went out briefly, and when it came back on. The unit will not power up. Is it fried ? Or is there a fuse inside the unit!
the best thing i can tell you to do is search google for the exact model it is and see if there is in fact a fuse in it if there is try to replace that if not it would most likely be fried.
Good Luck,
Cody
Make sure your line voltage (measured at the outlet) is there. It should read around 120 volts on a voltage meter in the AC setting. If it's not check your breaker/fuse at the supply panel.
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 482
