Aller au contenu principal
Sorti le 25 septembre 2015. Modèle A1688/A1633. La réparation de ce modèle est similaire à celle des versions précédentes et nécessite tournevis et outils pour faire levier. Disponible en GSM et CDMA / 16, 64 ou 128 Go / Argent, Or, Gris sidéral ou Or rosé.
iPhone 6s Searching/No Service
I have an iPhone 6s that has the searching/no service issue. I've seen this a lot online with the iPhone 6/6 Plus, but no one really talks about it with the 6s. Is it caused by the same baseband ic issue or is it another chip? I've looked around to get this repaired, but no one really seems to offer this service. Does anyone know where I can get this chip reballed? Thanks in advanced!
Répondu ! Afficher la réponse J'ai le même problème
Indice 17
6 commentaires
I had this problem after replacing the screen. I took the cellular antenna out (see youtube for videos) and cleaned using an alcohol screen cleaner (polaroid) and wiped with screen/glasses cloth. Put the antenna back in place and re-connected the battery and hey presto, problem solved. I was using the method of rolling the screen across my leg, which worked for a while. Also, I think warming the phone up helped as well, but cleaning the area where the cellular antenna is seated helped and got the iphone working.
par
https://www.youtube.com/watch?v=bSjJnFaU...
This is the solution, i tried every thing,about 1 week, no way to take back the signal, and this $@$* really worked
par
The video is unavailable...Can you please suggest another video?
par
https://youtu.be/7JvjR3WC37A New link to similar video
par
Thanks very much, man...I appreciate your help...
par
Afficher 1 commentaire en plus
Ajouter un commentaire
20 Réponses
Solution retenue
Give a shout out to @refectio here on IFIXIT, or search through the pros here on iFixit. If you cannot find what you are looking for here, search for Chris Long on youtube.
I've done several 6 and 6 plus, but not had the "6s or 6S+" with searching or no service.
Indice 11
3 commentaires:
Thanks for the recommendation. I found most of the places on google don't fix this issue. I'll contact some of the pros here to see who might be able to fix it.
par
I had the same issue and fixed it by replacing the lightning connector assembly. I was able to find one for $5 on ebay. Took about an hour to replace and this was my first time taking apart an iphone
Remplacement du connecteur de charge Lightning de l'iPhone 6
par
I have issue with my iPhone 6
par
Réponse la plus utile
The antenna may have become dislodged.
  1. While sitting down, turn your phone screen facing down in a horizontal position across your upper leg.
  2. Firmly rock it left-to-right across your upper leg for about 5-10 secs. (Be careful not to do it so hard that you bend your phone).
  3. Switch your phone to Flight Mode and back again to reinitialise the network search.
  4. Repeat if necessary.
This should re-seat the antenna and restore network connectivity.
I had exhausted all other software options, and this is the only thing that actually worked for me! I've been doing this for a few weeks now and it consistently restores service to my iPhone 6. I still lose network every few days (sometimes multiple times in a single day), but this method restores it every time.
Indice 22
17 commentaires:
This worked! Thank you!! :)
par
Thank you so much for this! Had my battery replaced by apple and it can back showing no service. Nothing worked! The people at apple were completely useless too when I went back. Stumbled on this comment and it worked!!
par
This worked great, thanks I did this and then had to reset my network settings and haven't lost service yet.
par
This worked a few times, thanks! After that I discovered that I removed the isolation tape while doing a repair. Just replacing that solved my problem completely.
par
wao.. perfect solution worked for me. i searched alot of solutions this look funny but worked for me after restarting phone. Thanks
par
Voir 12 commentaires en plus
This is pretty common for every 1/10 Iphones. I always review the following.
  1. Check for Carrier Updates, this is typically done with the sim and wi-fi connected.
  2. Check for iOS Update
  3. Test for Signal, if fail proceed to next steps.
  4. Look for APN settings on the phone and remove it, this can cause a signal interruption. I believe it's in Settings>General> APN. This does not appear in all phones and this varies on where the phone was purchased from. Some APNs can be found in Cellular > Cellular Data Options > APN/Cellular Data Network. Just look around to see if one exists.
  5. Test for Signal, if fail proceed to next steps.
  6. Manually search for a Network in Settings > Carrier (turn off automatic) see if you can manually search for the tower of your carrier.
  7. Test another Sim Card to ensure it's not a hardware issue. Frankly, some phones, primarily samsung, gets picky about the sim type you use. I'm not familiar with Sim Cards and how they function, I just know that if one type doesn't work try another type.
Hope this helps.
Indice 4
Have you opened it recently? If so, a antenna connector cable could have came lose or not been fully seated back .
Indice 3
3 commentaires:
It was opened recently. I've checked all the connections and done all the troubleshooting steps and it still seems to have the same issue.
par
How do I check the antenna connector?
par
it will like a string with a very small silver/ gold top part that connects to a small circle adapter
par
Hi all, i have the same problem. My sim card is being detected but I have no service.
The sim is working in another phone and the iPhone is water damaged,so I’m pretty sure it’s a hardware problem.
Do someone know which chip it is most likely? Or which chips are involved in this issue?
Indice 2
2 commentaires:
Did you happen to get yours fixed? I have the exact same issue with my phone having some water damage as well. =[
par
Ethio SiM Network On iPhone 6s_Plus
par
I have same issue. Probably software issue. Need downgrade or something upgrade to solve. My phone have iOS 11 update of 1.21gb size but I am not updating hoping my iPhone will die or any other issue will arise.
Indice 2
Then d baseband (network) ic should be replaced or reballed. Few Engineers do it in Lagos Nigeria
Indice 2
3 commentaires:
Where in Lagos please and at what cost?
par
Salad tinubu Victoria Island Lagos
par
Sorry It's Saka tinubu, I meant
par
yes this issue must be fixed by apple ,or file a suit
Indice 1
I have the same problem.
my phone works perfectly on T Mobile, it’s the model a1687 so it should have worked with Verizon but it doesn’t.
when you turn on the phone or after switching airplane mode on and off its says “searching” then it shows “Verizon” for a few seconds with no bars and then “no service till the end of times”
After doing some research I found out the problem, and it’s that Apple sucks in every conceivable way
Indice 1
Just putting it here because I had an 6s with the same issue and found that the culprit was the aerial jumper linkage in the top left of the phone, doesn’t look faulty but there was a definite resolution of the signal issue when it was replaced. It was initially very dirty so I cleaned it the first time but didn’t help. So if all else is failing then this might be just the answer you are looking for.
Indice 1
1 commentaire:
I have no service issue with my iPhone6s with 1 rectangle sign beside that no service
Please any solutions to it,have try software and hardware on it it still dsame thing
par
if no service or searching need to reball baseband or bbpmu (power managment for baseband)if its freeze sim no sim after few secconts replace u5411 ic and problem solvet…all time this problem happen after lcd replacement
Indice 1
Same problem here. Just wondering how on earth it could possibly happen? Worked fine from the start, and just stopped and now screaming "No service" all at once...
Replacing the SIM, resetting "Network settings", resetting ALL settings, and no luck!
Indice 0
9 commentaires:
I have the identical problem and it has been going on for months now. Slapping it on my knee and then resetting it and powering off seems to help occasionally. I took it to the Apple store and they said I needed a new antenna which would cost close to $300. As if. IHave tried all of the above fixes and they seem to be temporary if and when they do work. Doesn’t exactly give you a time and fuzzy feeling about having a reliable communication device with you for emergencies or otherwise! Think it’s time for a mass complaint . unless Apple can explain why this occurs so frequently to so many phones and it goes on and off class action suit Similar to their “battery” issue may encourage them to fix the problem/or prevent it from happening in the first place.
par
I totally agree!
par
Totally agree same issue!
par
@Stephon Resuah, I felt I wrote the comment you wrote, word by word! That was the Apple store's response to me plus a sarcastic: "your iPhone 6 is really old, it's time to change it anyway". I had a perfectly working phone until today and it suddenly stopped with the "searching" or "no service" sign on top left. All the soft, hard, software reset and restore didn't work. Apple looked inside and said there are no water damage which is a common cause of it. They said at the store: "this is common and the chip that reads the SIM just stops working at some point"! I felt their answer was pretty cocky corporate with a well-practiced sales technique to just buy-another-phone attitude. When are we getting enough of this buy-more-to-feel-happy culture?!
par
Apple Store didn't even give me a reason, other than I should really update my iPhone (hardware). Have to go back because didn't realize the tech actually locked up the phone and gave it back that way! Screen says to reset through iTunes, but keeps erroring out half way through. (plus no appointments yesterday, so going on day 2...). Not happy that I gave them a semi working phone (apps/internet/imessaging), and they gave me back a a phone that has NO value :/. We'll see if they can resolve later this evening...
par
Voir 4 commentaires en plus
I also face the same issue with my iPhone 6s.
Having a doubt. When some people fix the screen protection sheet, they press the screen heavily. Will this lead to this kind of problem?
Indice 0
1 commentaire:
No, that would not affect the signal.
par
Hello. See this video for fix Searching/No Service iPhone 6 on youtube : https://youtu.be/6rx_TOfgHqg
Indice 0
Dec 2018
same symptoms here. Above loose connector fix did not fix it. I also noted that when syncing to pc (itunes) that it always insisted applying a network patch. Just before opening my i6 l tripped across apples site saying to follow a procedure at their site to fix.
Support.apple.com/en-za/HT201415
or search no service or searching
Both iphone and ipad
my i6 is only 6 months old and lost my receipt so l am so glad this worked!
charles
Indice 0
I had this issue on a phone I was working on yesterday. I performed various tests including a new charge port with a new antenna with no success. It was a locked device so I couldn’t test it with a new sim card. It just suddenly began working again after trying for 45 minutes. Our master technician said it could have been a bad IC chip, which reballing wouldn’t have solved and it can’t be replaced. He also said that iPhone 6s, 6s plus, 7, and 7 plus have been known to have this issue every once in a while.
Indice 0
1 commentaire:
This may help and maybe not. I tried all of the above fixes and nothing helped. I rebooted the phone, took out the sim card and cleaned it, etc. As a last resort I reconnected my lightning plug and twisted it. It was back to functioning like new. Just my two cents. Good luck!
par
I recently got my screen replaced. Prior to that thou, ive never had this problem im thinking when he replaced my screen he might have accidently did something . when i shake it it does sound like something is loose. How do i open the screen? i dont wanna mess up my Ihpone6Plus. I really love this phone
Indice 0
May be I can help you with this …
Indice 0
4 commentaires:
Oh I hope so,
par
Just let me know what i need to do?
par
i have the same problem with iPhone 6s, can you help me.
par
I also have problem with my iPhone 6...he did not bring Sim card just writing searching..and my number is
09169174722
par
i have same problem iphone 6 Solution plz…
Indice 0
1 commentaire:
yep me too. 6s.
par
I’ll suggest two things to try. Do the first one and test for results. If no good then do the second one.
  1. remove the SIM card and clean the contacts with a pencil eraser.
  2. Follow the guide on iFixit for replacing the antennas. I did this recently on my wife’s iPhone 6 which was having cell connection problems. It was constantly dropping calls and the phone would indicate poor signal or no service. The GPS functions were also not working well. I replaced the antennas but might not have needed to. When I was disassembling the phone I found many of the screws holding in the antenna were loose. Making sure those connections are clean and tight could be the only fix you need. In my case I went ahead and replaced the antennas since I had new ones right there. The problem is solved in our case.
Indice 0
Ajouter une réponse
Daniel Grueneberg sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 39
30 derniers jours : 213
Total : 188,746
