Flickering when running on battery at about 65pct
My laptop screen starts to flicker when I run on battery at about 65 pct or less. But if I plug it in to ac it works fine. I have updated all drivers and it still happens. Can anyone help?
4 commentaires
I had the same. Spent all kinds of time searching. Do this. Make sure to plug your machine into another monitor. You'll probably find monitor is fine. You will need to change screen. Check harnesses also.
par charles
B*******. Change the battery
par Mike.the.teck
Bonjour;
j'ai eu le même problème:
j'ai changé la batterie sans amélioration.
j'ai changé l’écran et je n'ai plus aucun problèmes.
site pour l’écran:
https://www.ecrans-direct.fr/ppcshop/cat...
par Patrick Morard
thank you for your answer. I solved my problem by replacing the screen
par Patrick Morard
