MacBook shuts down after AC is unplugged
Hey!
I have a Macbook air and I am trying to figure out what is wrong with it. The macbook doesn't work without the AC plugged in. The battery does charge after I disconnect and then reconnect the battery and the I/O flex cable. But when I reboot it after that it stops charging again and only shows a green indicator. Hardware test, SMC reset, PRAM reset and complete factory reset did not do anything.
Battery info is:
- Battery Information:
- Model Information:
- Serial Number: D8612460820DKRNA7
- Manufacturer: SMP
- Device Name: bq20z451
- Pack Lot Code: 0
- PCB Lot Code: 0
- Firmware Version: 406
- Hardware Revision: 1
- Cell Revision: 162
- Charge Information:
- Charge Remaining (mAh): 3356
- Fully Charged: No
- Charging: No
- Full Charge Capacity (mAh): 5888
- Health Information:
- Cycle Count: 727
- Condition: Normal
- Battery Installed: Yes
- Amperage (mA): 18
- Voltage (mV): 7739
Everything is original in the macbook and I have already tried it with other chargers.
My main question now is: can I find out if it is the battery, the I/O board or the I/O flex cable?
