Aller au contenu principal
Entretien des véhicules électriques ou à essence, dénommés voiturettes de golf ou parfois golfettes ou carts de golf.
Questions au sujet de 344 Voir tout
Doesn’t want to run unless choke is applied?
02 Yamaha G16A
Freshly overhauled engine. Now it may idle a bit but the quits, will not gain rpm unless choke is applied. Air filter, gas lines and carburetor are all new or cleaned. What else do I need to look at?
Une réponse ! View the answer J'ai le même problème
Score 2
Ajouter un commentaire
2 réponses
Solution retenue
Dwight Coleman there are usually only a few possibilities if it only runs with the choke. One cause could be an air leak on the carb, head gasket, crankshaft seal. The other could be a clogged low speed and idle circuit. Since you just got the engine done I would double check the carburetor. You do want to make sure that it is set right and that it is clean. Check everything properly again and check for airleaks....
Cette réponse est utile ?
Score 1
Réponse la plus utile
Dwight check for a leak around the base of the carb . Make sure the gasket seated properly and that its torqued down properly. Use a propane torch to check for vacuum leaks around the carb . Don't light it just turn on the gas and move it slowly around the seams of the carb with the motor running . When the motor speeds up you found your leak. Hope this helps
Score 4
Ajoutez une réponse
Dwight Coleman sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 30
7 derniers jours : 99
30 derniers jours : 630
Total : 15,639
