iPhone 8+ and iPhone 7+ lcd
iPhone 8+ display compatibility and iPhone 7+?in Ches the difference
Sorti 22 septembre 2017. Modèles A1864, A1897. Disponible en version GSM ou CDMA / 64 ou 356 Go / Or, argent et gris sidéral.
Here's the latest info on the iPhone 8:
Both of them can't work well on each other. I write an article "What’s the difference between iPhone 8 and iPhone 7 LCD screen?", if you want to see it please see my profile then visit my blog. Also you can watch the video here:https://youtu.be/KxFovnbcY3E
Be VERY AWARE of chinese sellers on eBay trying to pass off iPhone 7 Plus screens for iPhone 8 Plus. They nearly look identical.
They looks similar but they can't work well on each other or say it not full functioning on each other,
No, you wouldn't be able to interchange displays between generations of iPhones. The 8 uses a 3 channel, temperature sensitive light sensor.
The 7 uses a single channel, light only sensitive sensor.
The ribbon cables are also likely different.
Yes you can put the iPhone 8 + digitizer on a 7+ iPhone.
And it will work just fine, only the display.
You need to use the orignal homebutton and sensor/frontcam cable.
The screws in the bottom wont fit unfortuanately
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 23
Total : 3,589
