Light bar, one burst of orange then nothing.
Recently I have swapped the analog sticks on my dual shock 4 because they had worn away.
After re-assembling the controller, it won't turn on without being plugged into the PS4 via USB. Once connected the controllers light bar, will pulses orange once and go black.
After this I can then connect the controller to the PS4, but only the X button will work, and the Triangle button will work, but act as the Circle button. None of the other buttons/analog sticks will work on the controller.
I have since re opened the controller, changed the ribbon connecting the light bar to the controller. But after changing this I've still got the same outcome.
I have also tried resetting the controller with the button next to the L2 trigger, but still the same result.
If you guys have any ideas on how to solve this, that be be amazing. Thanks =)
