Aller au contenu principal
Tutoriels de réparation et support pour les ordinateurs portables produits par Lenovo.
2555 questions Voir tout
3.5mm jack broke off and is now stuck
I (stupidly) used a cheap 3.5mm extension cable and the jack broke off inside my Lenovo Y50-70. Does anyone have an idea how to get it out? Or would I have to replace the entire audio IO part?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
1 commentaire
i tryed useing a nail and that not work i did not have super glue but i used glue and that dont work an now another one broke in my switch pls help me also tried the pen trick it dont work
par
Ajouter un commentaire
3 Réponses
Solution retenue
You can try using a plastic soda straw which is sliced so it can conform to the smaller diameter of the jack socket. Place the straw around the broken plug and slowly press it between the jack and plug once you’ve bottomed out you should be able to pull the broken plug out just like a cookie cutter does.
Here’s a metal version which I find is quite useful! GripStick Headphone Plug Extraction Tool
Image GripStick Headphone Plug Extraction Tool
Produit
$19.99
Indice 1
This has worked for me a couple times on phones - Grab the plastic tube inside a biro or pen (i have also used a q-tip with the cotton end cut off), melt the tip with a lighter for a quick couple seconds and when the melted plastic is still malleable, stick it in on top of the broken jack. hold it there for a few seconds to cool down and then yank it out, (hopefully) the tip will be stuck to the end!
I hope that works for you :) otherwise i'm sure you will get some helpful answers from the other folk around here
Indice 0
i found a usable but risky strategy of prying it out although my jack looks like blender blades were used in it
Indice 0
Ajouter une réponse
Luis sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 42
Total : 11,902
