Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Canon EOS 7D était le premier appareil photo professionnel haut de gamme de Canon équipé d'un capteur photographique APS-C.
pictures are either black or blurry on fast action shots
When we take fast auction shots the pictures are either blurry or are black. The pictures are ok on automatic. Have tried it both on manual focus and on auto and the results are the same. Have tried switching lenses and it still does the same thing........we need help!!
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
You know how the exposure triangle works, right? It sounds like the ISO is manually set too low at like ISO 100. Does it work in direct sunlight?
par
Ajouter un commentaire
1 Réponse
Solution retenue
Auto only covers the shutter time and f stop. If you want less blur with motion, you can either add more light (reduce the f stop) or increase the sensor's sensitivity to light (increase the ISO). For fast action like sports, try ISO 800.
The problem with high ISO is grainy photos, so don't go to high to fast so you can find what looks good to your eye.
If you get grainy photos at low ISO (under 300) or you are still getting blur with a high ISO (over 1600) then you need to reduce the f stop. This can be done with Aperature Priority mode. The lenses you use will determine how low the f stop can go.
Indice 0
Ajouter une réponse
Peggy sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 18
All Time: 399
