Mobile devices - phones, tablets, and laptops - are physically hard to assemble just due to the small form factors involved and the special tools needed. If it's a newly designed/patented device, especially by a proprietary company like Apple, spare parts on the open market will be hard to come by. The so-called "hackintosh", where mix-and-match PC parts are used to make a computer which can run MacOS, has been around for some time, but once the hardware is assembled which can run an existing version of Apple's OS, it often happens that a patch or system software/firmware released by Apple will cripple your hackintosh creation. It's consequently rather an expensive, time consuming hobby. You might actually save a little on hardware costs, but once you factor in the hours of time needed to construct and maintain a functional, up-to-date computer which will run a current MacOS release, the little saved on part acquisition is much outweighed by the labor outlay. Apple phones and tablet hardware upgrades, along with iOS updates, occur so frequently as to make assembly of a "hackinphone" a losing proposition. As Dan mentioned above, do you really have the time, money, and language skills to go to Asia to chase down parts?
A voté
Annuler
Indice
0
by parts do you mean you want to put the components onto the logic board yourself or just buy a logic board and the rest of the parts
par daniel
Buy all the parts and assembly them at home, like a pc
par Roberto Masaracchio
you could probably buy parts but as mandy says some parts probably arent available yet, you would need to find someone selling a working logic board. i cant even find a housing for 1 so atm i would say no chance
par daniel
Eventually? probably, someone did that with another iPhone model
right now? no
par Andrew Cassidy
Don't forget the FaceID probably is paired like TouchID by serial number. So unless it is done by Apple, FaceID most likely won't work.
par Kutter Ross
Afficher 1 commentaire en plus
