I have a Samsung Galaxy tab A SM-355Y. About 4 months prior it started to get hot when charging and using. Then one day whilst charging it got VERY hot and never turned on again.
Today l received a brand new battery for it, l then put it in (very difficult to open case), but following a YouTube video l managed to replace the old one.
About 1.5 hours into charging it up, l felt the back of the unit, and, as you’ve probably guessed, hot in the lower third section. So, it wasn’t the battery at fault!. So then l let it cool down, and then switched it on again (to try and isolate exactly where the heat was radiating from). The location turned out to be -, if you can imagine dividing the back into six sections - one line down the centre (top to bottom), and two equal lines side to side - now if you measured 2cm up from where the USB cord goes in and drew a line around a small soup spoon (between the two lowest sections of the case), that is where the heat emanates from. Now, having given that location, l have to tell you about a very strange abnormality, right bang smack in the centre of that ‘spoon’ shape, is something l that can only think of to describe as a ‘pimple like’ bump, (raised from the inside of machine, the bump being proud on the outside of the case) - l can give an exact location, - 4 cm up from USB port, in the dead centre. Possibly, what ever is causing the problem is behind that, and the raised ‘pimple’ has been caused by the heat of a faulty component directly behind there!
Can anybody shed some light on this, particularly what is directly behind the ‘soup spoon’ and the ‘pimple’ areas?
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
12 commentaires
I have the exact same problem with my Nexus 9
Did you end up finding a solution?
Carlos
par Juan Carlos Dunick
I have a Amazon Fire Tablet and it heated up really bad where the power button is. Now it just wont turn on...even when charging or holding power button Down! Does anyone now how I can fix this?
par Reaoxo
I ran into this problem after plugging in a Samsung USB adapter into my galaxy tab SM-T560NU. Battery life was hovering at 53%. Plugged in the adapter and the battery died instantly. ? So I plugged it in and the %#*@ thing started heating up. Still won't charge and I'm not willing to go the distance with this thing to see if it goes ballistic.
par Tony Stark
This is a common issue with most tablets and usually it starts affecting it the older it gets as the MotherBoard could break down. A short term fix that I've found is to cool the tablet by placing It on an ice pack or putting it in the fridge for a minute or 2. This could help to turn it on but is again only short term.
par WinterSoldier0
I have same problem it keeps heating a motherboard don't know why, the think is it was working just fine before I had to charge it and since then I couldn't switch it on or see if it charging.
par Jeo
Voir 7 commentaires en plus
