iPhone 8 lcd flex compatible with iPhone 7?
Hi, I have a question: Is the lcd flex cable from the iPhone 7 compatible with the iPhone 8?
Sorti le 22 septembre 2017, modèles A1863, A1905. Disponible en version GSM ou CDMA / 64 ou 256 Go / Or, argent et gris sidéral.
I tested is working perfectly!!
Commentaires:
I tested it working perfectly!!
par tecu mada
It really works?
par Rafael Borja
I had my iphone 7 screen broken then my sister had a broken iphone 8. Can i use the iphone 8 screen on iphone 7?pls i need help thanks
par Rafael Borja
From what I've been able to tell looking at the connectors the LCD may be compatible but the digitizer is not.
iPhone 8 LCD SCREEN install in iPhone 7, the phone works but touch function is not working. So it is not compatible.
If you want to break your phone, put a 7 screen on an 8.
Commentaires:
How does it break it? What damage are you saying it causes?
It may damage the 3D touch connector, the iPhone 7 3D touch connector is bigger than iPhone 8
par Arvin
any solution for this?
we test a good ip7 screen on ip8 suddenly touch screen not working
even we install back ip8 original lcd screen
par Arch Sal
You have to replace a new LCD flex cable connector on the iPhone 8 motherboard. More details you can read here:https://www.etradesupply.com/blog/how-to...
par Mandy
Thats True , i did , now my iphone 8 plus , touching not working .
par Rawa Nabard
This thread is really worrying, stick to the same model screen, it is really better to play it safe then to make a $400+ phone damaged.
Unless you don’t mind taking a risk of damaging the phone as said by others the screen connector on the board will get damaged due to different size of ribbon cable plugs on the screen itself..
Dernières 24 heures : 3
7 derniers jours : 16
30 derniers jours : 103
Total : 3,911
