Aller au contenu principal
La version 2016 de la série d'ordinateurs portables Apple destinés aux professionnels. Dispose d'un écran Retina de 15 pouces, d'une résolution de 2880 sur 1800 pouces, processeur quad-core Intel Core i7, 256 Go / 512 Go /1 To / 2 To en options de stockage, RAM de 16 Go et un clavier équipé deTouch Bar. Sorti en novembre 2016. Numéro de modèle A1707.
259 questions Voir tout
The keyboard fell into the juice
After the juice is dried Question mark Insensitive How to clean the keyboard yourself
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
Ajouter un commentaire
3 Réponses
Solution retenue
You will need to replace the keyboard. Cleaning it will not do anything. However, this machine is very new so finding parts will be very hard.
Indice 2
5 commentaires:
How long does it take to change the keyboard, about how much money?
par
I think I have seen these keyboards recently on AliExpress for ~80$USD. Might be able to get lucky with that one.
par
To the OP. Replacing the keyboards is a huge pain. I am a tech that does motherboard repair and I still don't do them unless I have to. It's just a big pain.
par
Is there a guide for doing that on this machine?
par
@mayer No sir. A teardown but doesn't show the painful task of lifting the backlight and clipping the 50 or so rivets.
par
Try using USB keyboard.
Indice 2
I literally just fixed one of these with a coffee spill, I would not recommend a non-tech replacing this part. A keyboard replacement means you need to change the entire bottom part of your computer (minus the trackpad and logic-board). I was able to find the part at a steep $800 (my cost) not to mention the labor the swap it out. An external keyboard (props to Anna) is the easiest solution for now until the parts become cheaper.
Indice 1
1 commentaire:
Just out of curiosity, have you tried sticking the keyboard in an ultrasonic cleaner? Probably nothing to lose. Either way, I would suppose the top case would be worth quite a pretty penny on eBay even if the keyboard needs to be changed...
How did you deal with the touch bar?
par
Ajouter une réponse
zxf sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 217
