Screen Broke - Can you get replacements yet?
We recently bought my son an apple 3 series watch (GPS only). Unfortunately, he fell off his scooter and bumped the watch resulting in the screen breaking. The display still works, but just need screen replaced. Is it possible to order screen and repair oneself?
People from Ifixit, the complete screen from serie 3 is same as serie 2? Need to replace any ic or flex from the cracked lcd to the new one? thanks
par Diego E. Rojkis
The Series 2 Display will work on Series 3. However there is a sensor (ambient light I think?) that gets very hot. I think if you transplant the sensor from the broken Series 3 Display onto the replacement Series 2 that should do it.
I've seen some references to there being an antenna integrated into the Series 3 Displays? But I haven't seen anything that looks like an RF connection to the Series 3 Displays so I think that's probably incorrect.
par Gordon Hlavenka
Gordon, do you have any information on how to replace that ambient light sensor? I recently tried to replace a series 3 screen with the series 2 and I am noticing that overheating problem. The watch essentially turns itself off after a little while and the screen needs to be detached and reattached to work again. I can’t find any good information on how to transplant that sensor.
par Andrew Buck
This is just theory; I haven't tried it yet. But I don't think there's any electrical connection between the light sensor and the rest of the Display assembly. There are a couple of solder connections to ground, but I think they're more mechanical than electrical.
If you stick a blade under the sensor on the broken S3 Display, you can just chisel it off and then use some mounting tape to stick it onto the S2, in place of that sensor. Should work, but like I say I haven't tried it yet. They've got me pretty swamped with Series 1 and 2 right now at work.
I've also found that most S3 Watches won't pair ("Unable to pair" or "Activation error") when they have a S2 Display installed. If the broken Display is good enough you can pair using that (you don't need a working digi to pair) and then switch in the S2. Pretty sure this problem is fixed by updating the WatchOS with the new Display installed. A lot of our S2 repairs need this after a Display replacement.
par Gordon Hlavenka
Andrew, did you ever get the Series 2 screen to work in a Series 3? I have a 38mm Series 3, and can't find a replacement screen anywhere. I can find 42mm... just not 38. My wife shattered her watch face, and I'd like to replace it so she doesn't have to buy a whole new watch.
par Dana Hallenbeck
Voir 7 commentaires en plus
