Aller au contenu principal
La version 2016 de la série d'ordinateurs portables Apple destinés aux professionnels. Dispose d'un écran Retina de 15 pouces, d'une résolution de 2880 sur 1800 pouces, processeur quad-core Intel Core i7, 256 Go / 512 Go /1 To / 2 To en options de stockage, RAM de 16 Go et un clavier équipé deTouch Bar. Sorti en novembre 2016. Numéro de modèle A1707.
259 questions Voir tout
Possible to save MacBook Pro display connector?
Spilled yogurt into the right vents, and it got into the display connector. Logic board and everything else seems fine (yogurt never got there).
Here's some images: https://imgur.com/a/zFL48
What's my best option?
- Clean it with alcohol?
- Order a replacement screen (they go for around 300-400USD)
- Send to apple and PRAY they don't charge me >1000USD (no AppleCare :( )
I tried to turn it on after 48h in rice, and it did work, albeit with weird transparent bar going on and off every few seconds.
Can I test that the screen connector IS the problem?
Any help is greatly appreciated in this time of frustration.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Before you send it to apple at least try plugging it into an exterior monitor. This way you can see if it is the connector going to the screen of your mac or if it is something else.
Indice 0
3 commentaires:
Can I do it without connecting the macbook screen?
par
If you have an adapter for HDMI such as the lighting cable to HDMI similar to what a person would do if they were going to dock it at a work station. Then use the keys at the top of the keyboard to switch the display.
par
Yeah I got a hyperdrive with HDMI. Thanks, will try it out.
par
Sorry Rice is a myth! It does not work on yogurt only water ;-{ And it only pulls moisture out of the air not wetness like a spill. Besides, just like when you spill your coffee the solids will still be left which can be more harmful concentrated. If you had opened it up sooner you likely would have saved it.
While connectors on this side look bad how does the main logic board connectors and the ribbon cable? If they are clean you have a chance here in just replacing the display assembly. If they look as bad then you may need a new ribbon cable and possibly a new logic board as well. FYI the connector is hidden on the backside of the logic board.
Indice 0
Ajouter une réponse
Austin sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 1
Total : 918
