Aller au contenu principal
La version 2016 de la série d'ordinateurs portables Apple destinés aux professionnels. Dispose d'un écran Retina de 15 pouces, d'une résolution de 2880 sur 1800 pouces, processeur quad-core Intel Core i7, 256 Go / 512 Go /1 To / 2 To en options de stockage, RAM de 16 Go et un clavier équipé deTouch Bar. Sorti en novembre 2016. Numéro de modèle A1707.
259 questions Voir tout
Automatically shut down once in the loading screen
So, there’s this day my laptop put inside a bag together with my water bottle and the bottle cap came off eventually flooded the whole bag. And unfortunately my laptop is inside and sinker I think 1/4 of the laptop from the fan edge there and touch bar. After I let it dried it went back to normal, but around 5 days onwards when I shut it down it start up slowly and once in the loading screen it shut down on itself. I can only start the screen when I pressed down for >3seconds, normally 1 quick press should start up the screen but now it doesn’t. Anyway is it the logic board problem? The screen is perfectly fine though. Hope to find help here!
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
At this point you'll need to open it up and clean out the water and any corrosion. It's a bit of work and you'll likely need parts which presently are hard to get.
You might try going to an Apple authorized service center to see if they can help you. One of the problems with wet systems is the battery can damage the circuitry if left connected. Spring/Tap water has minerals which creates issues when you add in the batteries power.
You might want to see if your insurance will cover the damage.
I wish I had better news ;-{
Indice 1
1 commentaire:
@danj
Hi there Dan! I’m gonna send my lappy to a apple authorised machines later morning or afternoon. I’ve checked other forums that when it contacted with water usually they wanted to change the whole thing and cost almost cost a new above average standard laptop price to repair it. If let’s say it is, should I repair it no matter how much the cost? As it is a bloody expensive! Or move on to a new laptop? Btw FYI, I’m an architectural student and I’ve found out that apple is a pain in the ass sometime when it comes to SketchUp and such though it advertised it handles pretty well. Thanks for the time! :)
par
Ajouter une réponse
Jonathan Tiong sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 58
