iPhone Replaced Battery now sleep/wake button and video mic won’t work
Recently replaced my iPhone 6 battery. Now the sleep/wake button won’t work as well as faint-scratchy/no sound recorded on videos.
Ok, I should've just posted my answer earlier. So you've damaged some stuff while doing your repair. The power button, which is connected to the volume/mute, which you'll have to remove the battery and the logic board. It's a pretty big repair. Youve also likely damaged the front camera flex assembly. Not that big of a job. I mean you should check that and make sure you properly seated the connections. But likely you'll have to order new a new one
Remplacement du câble du bouton de marche de l'iPhone 6
Remplacement de la caméra avant et de la nappe du capteur de l'iPhone 6
Produit
$19.99
Produit
$9.99
Tutoriel
Difficulté :
Difficile
1 - 2 hours
Tutoriel
Difficulté :
Modérée
30 minutes - 1 hour
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 211
2 commentaires
Does you volume/mute switch work?
par iMedic
Yes it works.
par eric collins
