Aller au contenu principal
Le Fujitsu Lifebook T902 est un ancien convertible qui combine l’avantage d’une tablette et d’un notebook. Un nouveau boitier, de nouvelles technologies et un produit classique orienté business, il est conçu pour répondre à des attentes élevées concernant les performances, la qualité et les fonctionnalités.
Questions au sujet de 4 Voir tout
3 laptops with Windows 7 Ult reinstalled won't reconnect to network.
I recently installed a new version of Windows 7 Ult. onto three computers. two were Fujitsu, one was Dell, previously they had Windows 7 Pro. One has given me no issues, the other Fujitsu connected to the every network fine, but then wouldn't connect to the office network. After bringing it home, and connecting it to my network, it said there was a problem and the diagnostic fixed it.
The Dell reacted the same way, connected to everything fine, then when it goto the office it connected fine, but then after it was brought home, when it went back to the office, it didn't connect. At this point, the only computer that is causing problems is the Dell, it says it is connected, but the browser isn't working at the office. It works fine at any home network.
Any ideas?
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire:
Check the connection settings, is it set for Auto or set to a setting that is not supported by the office network. Does the office network require a sign in?
par
Ajouter un commentaire
1 Réponse
you can try to restart your computer at the POST press f10 then click on restore default, then exist, then save the changes if you pc will continue having this problem then there will be a problem on your network card which is in the motherboard of your pc
Indice 0
Ajouter une réponse
gatewaynomad sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 96
