Aller au contenu principal
Repair and troubleshooting information for the Suzuki FA50 Moped.
75 questions Voir tout
Engine won't fire could it be worn rings?
Won't start even with starting fluid. Good spark. Measured compression and got 30 psi. Rings ? The reeds also look ok. Not sure what's next
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Hi Rich ,
Your compression is way too low . I like to see it at something close to a hundred pounds or better .
It will run at lower compression , but , along with that comes lower over all performance .
You could try a new set of rings and a hone ( necessary with new rings ) . But , if the rings are that far gone , I'd think a much better solution would be a next oversize piston set ( piston , rings , clips and possibly a new wrist pin bearing ) and a bore job to match .
Indice 0
Ajouter une réponse
Rich Henry sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 230
